Hello.
The lower part of these external walls were mouldy, so I removed the wallpaper to find this.
You can see from where I've opened up a small hole, that the render is straight onto brick (Victorian, solid wall, but cement render on the exterior).
The lower part of the walls have mostly been re-finished in something grey & quite hard - any idea what this is? Could it be Gypsum based & exacerbating the damp/mould?
I'm assuming the original finish was sand/lime, is that right?
There's areas which look like they've been repaired/blended with modern plaster, but it's all a bit pink, so I'm pretty confused and definitely not sure what the best thing to do now is - I was supposed to be decorating!
If anyone can offer clear insight, I'm all ears.
Rupert.
Rupert.
