Curry
I've pretty much been sponging since I started learning plastering just coz the guy I learnt off used to do it, but I still always two coat, now that I've splashed out on some new tools to make things easier, I put it all on as normal, speedskim, then lay it down speedskim again, clean everything buckets etc while waiting a bit, then spray a small bit of water over the whole wall and float it all up, got one the the big Refina sponges, then take off with plazzi which spreads the fat into any tiny little bits, let it pick up then wet trowel dry trowel all with plazzi, normally try and get edges better on each trowel leaving just slight touch up at the end, probably a bit overkill but trying to get a good name for myself ATM so just going the extra mile a bit I guess:/
Got the spray bottle from Jewsons, expensive for what it is but I've gone through so many cheaper ones and this one is the dogs!
Do you not use steel at all?
