Newly boarded and skimmed ceiling cracking?
Mike googlebottom
@Ritch judging by a ceiling pic I've seen you skim you could do with going back to college..you need to get your timings more accurate..your going over it too early..like the river Thames on 1 of pics I seen..abit of constructive criticism for you :inocente:
D
Deleted member 32554
Guest
600 centres need 15mm ceiling board/grey
I usually cross batten over board at ,400 , down to the customer at the end of the day , I only charge labour , no responsibility lol
Ritch
Lol I can’t take criticism from a site board butcher.that ceiling/room is south facing all day in the sun , pancake flat. U monkey
lurpak
Artex Boy
@lurpak yer dogs got loose,put a muzzle on the bitch.
Stevieo
Royal Spin Doctor
That's best for the sake of a couple of baton.
Different when it's 9'' timbers or trusses. Well worth saving a few of them.
Dollar
You have screwed the 9.5 up
However you should only break the paper on the board with the screw
You have gone too far into board That is the reason it is loose
& cracked
Your welcome
lurpak
Artex Boy
& cracked
Your welcome
on every screw? That you tappy?
lurpak
Artex Boy
Yes I am right but I will explain
Method to screw most likely impact driver
9.5 not supported @ right centre
It’s not brain surgery
Your welcome
i use ID never had an issue. the odd screw maybe but not the whole lot thus your arguments invalid
You’re welcome
Dollar
You’re welcome
If you read the post it is a builder
Who has done this boarding so impact driver & 9.5 boards massive centres
End of thread
Your welcome
