lurpak
Artex Boy
so you wouldn't skim the patch ,just paint over it?
Every time you type you reveal a bigger fool.
The irony is killing me. Keep going
yes mate, have a couple on here.only if there are sufficient noggins too.... but you were going to say that weren’t you?!
You still need to tape and skim over the jointsso you wouldn't skim the patch ,just paint over it?
only a chancer would not keep some 9.5 board handy for patching 9.5 boarded walls/ceilings.seriously @tapit lol. Id use whatever i had for a little patch. 9.5mm is rare as rocking horse s**t on re skims for a start.
If its9.5 n you only have 12.5 for a PATCH. Peel paper off , flat it back. Pva. Scrim n skim. Theres always a way. Only someone who doesn’t know what they’re doing would leave the job to buy a 9.5 board for a lil patch.
if you’re really scared just feather further out
What timber did you screw in to and what is abouve.Hi there, I am new to this forum but would be very grateful for some advice from fellow plasters. I have been in the building trade for about 20 years and in the last 10 years set up by myself and taken on a lot more plastering work. however, a few months ago a took down an old ceiling in a massive kitchen, moved a wall, re-boarded it with 9.5mm boards, skim taped it, screwed it up exactly the same as I always do and skimmed it. Then 3 months later it has started to crack and has come loose in places. The house owner is obviously not happy and has left threatening voicemail messages on my phone. He thinks the timber we screwed into wasn't thick enough and so he and the other builder I was working with have put in a lot more timber above and re-screwed, filled and repainted but it is still cracking. I really don't know why this is happening. I haven't done anything different to any other ceiling I have boarded and skimmed? I am going back today to try and work out why this is happening. It is a 80's built bungalow so there is nothing above the kitchen. My initial thought was that the thin factory made trusses they used in the roof maybe causing slight movement to the ceiling? The owner of the house is adamant that this is not caused by movement from above and is because we haven't screwed the boards up properly but I didn't do anything different to any other ceiling I have done. I really don't know why this is happening, can anyone help?
Was just about to mention that , nice warm room on a freezing day and patio doors flung open , have witnessed it pingWhat timber did you screw in to and what is abouve.
We did one a few months back . We never boarded it and was for over kids sister . He told her joists were wrong. Anyway it was a good five bagger and he told me ever joint had a crack . Then a few weeks later he sid all cracks had gone. No one had filled em put it down to joists expanding
use 12.5s and feather it back, ha ha ha hayou’re fooling nobody lol
This was on a new build. They had to do summet to em at first as they were shaking when people went up stair.Was just about to mention that , nice warm room on a freezing day and patio doors flung open , have witnessed it ping
He's bloody useless. Cuts corners on every job. If you gave him some 12.5mm to patch up 9.5mm ceiling he wouldn't be able to work it out lolare you f**k**g joking or what. 9.5 board skimmed. 12.5mm will be approximately flush. Then skim n feather in as normal.
Spreads? you should be reported to the f**k**g plastering police.
Interesting fact about rocket science , when injecting fuel if you electrically charge it with a small DC battery then when injected the fuel particles repel each other and burn betterthis is my point. It’s not always straight forward but there’s always a way it’s plastering not rocket science
working on this at the moment View attachment 43337
You not know what cracks look like?put some pics up when you go back!
put a selfie upYou not know what cracks look like?
Movement of the house isn’t your problem. For example in my house ceilings in living room and upstairs bedroom had big crack running right along them. I dropped both ceilings, double sheeted with sound block staggering the joints different ways each time I boarded and the cracks still came back in exact same place on both ceilings. Had a customer try to get me to sign an ‘agreement’ which had been drawing up by a solicitor which stated if I started work repairing the crack in his ceiling I was to be held responsible if it came back within ten year lol he’d had a few plasterers attempt to fix it but it always came back.Hi there, I am new to this forum but would be very grateful for some advice from fellow plasters. I have been in the building trade for about 20 years and in the last 10 years set up by myself and taken on a lot more plastering work. however, a few months ago a took down an old ceiling in a massive kitchen, moved a wall, re-boarded it with 9.5mm boards, skim taped it, screwed it up exactly the same as I always do and skimmed it. Then 3 months later it has started to crack and has come loose in places. The house owner is obviously not happy and has left threatening voicemail messages on my phone. He thinks the timber we screwed into wasn't thick enough and so he and the other builder I was working with have put in a lot more timber above and re-screwed, filled and repainted but it is still cracking. I really don't know why this is happening. I haven't done anything different to any other ceiling I have boarded and skimmed? I am going back today to try and work out why this is happening. It is a 80's built bungalow so there is nothing above the kitchen. My initial thought was that the thin factory made trusses they used in the roof maybe causing slight movement to the ceiling? The owner of the house is adamant that this is not caused by movement from above and is because we haven't screwed the boards up properly but I didn't do anything different to any other ceiling I have done. I really don't know why this is happening, can anyone help?
Caulk.Movement of the house isn’t your problem. For example in my house ceilings in living room and upstairs bedroom had big crack running right along them. I dropped both ceilings, double sheeted with sound block staggering the joints different ways each time I boarded and the cracks still came back in exact same place on both ceilings. Had a customer try to get me to sign an ‘agreement’ which had been drawing up by a solicitor which stated if I started work repairing the crack in his ceiling I was to be held responsible if it came back within ten year lol he’d had a few plasterers attempt to fix it but it always came back.
Flashes when paintedCaulk.
Shows you its cockWhat do you mean flashes?
9.5 for 400 , 12.5 for 400/450 and 15mm for 600. Extra nogins are required etcI thought it was now meant to be 12.5mm for 400 centres
15 mm for 600
no mate,600 for both 12.5 and 15mm.I thought it was now meant to be 12.5mm for 400 centres
15 mm for 600
No it's not. Unless there's alot of nogginsno mate,600 for both 12.5 and 15mm.
how many times you need me to prove your incompetence in one day?No it's not. Unless there's alot of noggins
