Just a small point but if you think that adding more layers of plaster to a ceiling might make it unsafe and you tell the customer so ,why would you then go a head and carry out the job knowing that in your opinion it is creating a potential danger.:RpS_confused:Hi Conditor,
Welcome to the forum.
L+P with an artex covering is already putting a weight burden on the ceiling. You should be able to keep the coving in place: measure the rough average of the stipple and add 3mm for the skim. Is there enough of the coving profile remaining? If yes, then use a bonding agent followed by a tight coat of skim or bonding to hide the stipple. Then finish with another two coats. It's the only solution if she doesn't want the ceiling replaced. However, make her fully aware that you're adding even more weight to the ceiling now and there's no guarantee that it will remain in place. She should also be made aware that water from the plaster might cause some of the paint to peel off the edges of her coving.
Best regards,
Minh
The op says the stipple is like inch and a half deep clumps???there will be half of covin left when he's done!!:RpS_unsure:
It's her decision![]()
Glad your not an electrician or a gas fitter then.:RpS_biggrin:That's what liability insurance is for![]()
ok spunky ive often wonderd just how bad or not that stuff is.Asbestos in artex is minimal enough to scrape back
