Although I am a joiner by trade, my query is very much from the perspective of a plastering DIY'er. Having done a number of smaller plastering jobs I have the deepest admiration for the professionals. It takes me ages, it exhausts me and my finish is only so-so.
I insulated the walls of the top floor of our house with 60mm foil-backed insulated plasterboard. The house is one end of a 1960's 2-storey solid stone barn conversion, upside-down house with a large open-plan kitchen/lounge/diner upstairs. Although I say so myself I did a pretty good job... perfectly plumb and level with invisibly skimming joints, and.... the thermal gain is astonishing.
The flat ceiling was already insulated but I seem to get some cold-spotting along the a 4 to 6 inch strip along the gable-end ceiling edge. It shows as darkening of the white vinyl-emulsion paint caused by the ambient moisture condensing on it.
My analysis is that the ceiling edge is drawing cold from where it touches the rendered and plastered stonework, and that maybe what I should have done before I insulated the walls was hack-off 30mm or so of ceiling along this gable-end edge... maybe filling with the same gun-foam I stuck the boards on with.
Anyone had, or seen, this problem. If so... what easy-fix cure can they recommend.
The room is well ventilated with powerful kitchen extraction... when she switches it on.
All I can think of doing is applying coving, or using some type of ant-condensation paint.
