Help please ?
I have a conservatory with an external brick wall that my partner wanted plastering so I did 2 coats of bonding then waited for it to dry then yesterday on a hot day started plastering it. As the sun came around it got hotter and hotter an before I knew it my hawk was drying up and my plaster was getting harder by the minute. I managed to get the first coat on fine but the second eas tuning out to be a nightmare. Soon after the cracks came . I had pva the wall(1coat)before starting but I'm thinking the heat has dried it out too fast and maby not enough Pva ? I'm thinking maby board it then skim as somethings telling me I'm going to have trouble with this wall I have pictures if I can post them. Any advice will help thanks..
Oh btw it wasn't hot when I started it the sun came around the back of the house and even with window doors open was sweltering
Danny
Administrator
The heat is not good for that.... I would pull it off and I would probably plasterboard it if you could
John j
Mono Don
Think its down to what you skimmed on to as well as heat . Done some conni.s qhen its been steaming and not gone that bad
Topspread16
You’ve not controlled the suction, on backing plasters that have been on a few days I soak it with water then 5-1 pva then 2-1 coat of each. Will seal the water in then.
Thanks for the info. So it looks another nice day so will put it off until it's abit cooler. I will follow them steps then have another bash at it and if same again il just board it up also there's a fuse box in the left hand corner that she wants boxing in so if it comes to boarding would I be best boxing that in first then bording the wall as then I wouldn't need to fix it to the board would that be better ? Thanks
How wide r those French doors. Boards all the way
Just over 1m not very big. Yeh I am just going to board it. What's the best size wood to use as I don't want to bring it 2 far out. I think il have to take that door frame out and plaster board that 2 otherwise the plasterboard will come out further than the door frame . Thanks ppl for info
John j
Mono Don
Could do a return in to door and do away with arc.s maybe. Bet check ye cables are long enough to board as well. You want to add owt @zombie
Olican
Bum Fisting Club
I've just been on TMF (www.TheMechanicsForum) basically the head went on my van so I googled the process and it said the gasket seal neaded replacing but the head would need stripped and cleaned.. I used my hammer and bolster to remove the head then after running my surform over the head I ran some scratch over it. Lost the bolts so I used some drywall screws instead.. everyone on TMF was incredibly helpful and sympathetic to my situation. My van is now a write off but at least I had a go
John j
Mono Don
Size drywall screws you use
Yeh that's what I'm going to do. Will look a lot nicer. I've done the rest of the house but left that until last as I've never worked from a brick wall apart from rendering it then scratching but yeh I think bording it all is the best option and there's a load of cable behind them arc's.so busy day tomorrow. Cheers
essexandy
The Lake Governor
Why would I pay a plasterer when I can do the job myself. Asking abit of advice dont mean I can't realy come on mate 2+2=8 ?? Nah fort not
But you can't even choose the correct materials let alone do the job!
@zombie I hope I'm not treading on your toes here but........
KNOBHEAD!
Listen KNOBHEAD I will send you a pic of the finished job n you'll see won't you about can't even get right materials what was u thinking dot n dab ? Nah mate I'm handy with wood so think il do my thing n stick ur 2 penath up your arse. So All's well and shits ok so il end this s**t with a f*** you but have a nice day.
algeeman
It’s A Boy
To me it looks like you've skimmed more or less straight onto the bricks.....there's hardly any bonding there.
That's why it's blown.
I've just had a closer look and I've noticed you more or less have skimmed onto the bricks you daft cuunt lol.
Or whatever daft cuunt done it :X3:
Yeh there's about 6mm between the brick n plaster 2 coats your looking at a head on picture at were the door frame was going back down so there ya go #JOCKUM
