S Sam9696 New Member Feb 17, 2023 #1 Has anyone used Gyp Prime for walls before Dot and Dab? Sand lime bricks walls suction level is too high even with 2 coats PVA. I know its expensive but not as expensive as re doing it!
essexandy The Lake Governor Feb 17, 2023 #4 zombie said: Hose pipe Click to expand... Someone should whip him with a hose pipe? The idea has some merit for sure.
The Apprentice Well-Known Member Feb 17, 2023 #5 Sam9696 said: Has anyone used Gyp Prime for walls before Dot and Dab? Sand lime bricks walls suction level is too high even with 2 coats PVA. I know its expensive but not as expensive as re doing it! Click to expand... Its fine for that, I’d suggest letting it down to suit the substrate but don’t kill the suction
paulf Well-Known Member Feb 17, 2023 #6 Sam9696 said: Has anyone used Gyp Prime for walls before Dot and Dab? Sand lime bricks walls suction level is too high even with 2 coats PVA. I know its expensive but not as expensive as re doing it! Click to expand... Just get rid of all dust and debris, wet it down if you want, as far as suction goes just work faster.
K KingCharlesTheTurd Active Member Feb 17, 2023 #7 Reckon at least 95% of spreads on here have never even heard of gyprime never mind used it
