What is going on with multi finish!?
Okay I want to actually know what the hell is going on with multi finish it is definitely not the same. It's behaving like my trowel hasn't worn in yet, tears slightly on final trowels?? Feels stodgy, gluey, seems gritty and coarser than normal.
My question is most of my work is overskim can I just fu*k multi off for good and use board finish instead never had trouble with board finish but have only used on board???
McBentLegs
I use board for everything, although on job for a builder at the minute and he got multi.. Fine this time round, although last job I did for him was horrendous, awful gear.
Well I've got batch number so I will send to BG I used multi couple of months ago and didn't really have trouble then. My problem with it now is it just seems to be more miss than hit. Or...
Maybe I am genuinely getting worse??
Can't see how that would work but you never know, anything would have been better than the utter crap I just used. But does mean you need a bag of dab to hand which I don't
Zippydragon
It is definitely a bit off at the moment. 2 bags I had yesterday were greasy and gritty. Ah well s**t happens
D
Deleted member 32554
Guest
Out of interest , where did you buy it and what's the date
essexandy
The Lake Governor
Also could be onto something about them changing the formula to better suit plastic rather than steel..called it 2 years ago
I truly and honestly don't think that the c**ts at BG give a flying f**k what trowels we use or how decent a finish can be achieved.
That's what happens when you're buying off an effective monopoly.
