refina and nela are very good.. I just dont go on about it every other fukin thread...Lol as I see you love Refina Craig?![]()
I love the way at the end of the vid it says "tried & tested"
I'm sure they said that last time :RpS_lol:
I'd like to to know how they tested it to see if it doesn't shell off![]()
i realy want this product to be mint however surely if your there staring at the wall before you start knowing that on those mega porous aresas are going to be a drama I just cant imagine not paving at least those areas as hes had to adapt how hes working to accomidate the product when it should be the other way around
ie the product should have enough meat about it to not be overly affected in the first place or am i missing summet? dunno???:RpS_confused:
why do you wanna pave them for..........................your skimming not laying slab, man..............................:RpS_biggrin:
It actually said it was tried & tested by you....................................:-0
Can believe your a BG "yes man".............................................bloody turn coat
gulp...coz imbetween sets I knock on old peoples doors to try and tarmac there drives:RpS_blushing: / cant spell:RpS_blushing:
cheers John, I tried to cover the basics, timing, coverage, suction etc.
It's crack resistent too as he didn't seem to put any mesh or fibres over the ones on the lime wall!
No comebacks so far from Oli and Arti and Scottie who used it a while back?
Needs to be tested with feedback for another 6 months IMO.
I'm going back to the job in my video in a couple of months to render the outside so I will check those walls with a hammer.......:RpS_thumbsup:
I've done one of these vids and I'm dreading seeing it. Used 15 bags of the stuff and not that impressed with it. During filming on high suction walls I was told to go straight back over my first coat with the same stuff as it was pulling in so fast. My reply was if I'd just pva'd it I'd have been fine. Why three coat with more expensive gear??
ansome............................:RpS_thumbup:
I don't understand why folk feel the need to use expensive products when pva does the job
I don't understand why anyone wouldn't pva a high suction area, it will dry out quick enough. For me the only use to this product would be for glossy areas where pva hangs around.
im a lazy **** and if this works and its not over priced i would use itI agree, why bother with unifinish, when PVA takes no time to apply and you know whats what...
It will probably say on the bags that in some instances the use of thistle bondit may be required!
