Skimming over render grip
I tried it once on artex ceiling.... never again. Very thick and don’t spread well one of the bonding agent designed for outside and stay there! Smells strong too.
Wonder if you filter the grit out then added half back if it would be better?
I found blue grit to be be too gritty
We only use blue grit...definitely use alot of multi...I tend to back roll blue grit to flatten it.
Red grit is expensive but you can top it after an hour usually.
