There not judder marks there more spaced out like little bumps, I spot them then go over with the trowel but they just don't push out. They always go the same was as I'm troweling. At what point should the plaster be before I start troweling. I might be troweling too early I trowel when its taken just a little bit but still quite wet. Thanks for the advice guys
Ankers,
This is the how I teach my students the difference between ripples and tiger stripes.
Question: What causes ripples?
Answer: Plaster that has been laid on too thick.
Reason: When you pass the trowel over a thick coat that has not pulled in yet, you end up causing some parts of the plaster to slide over itself causing ripples. Multi finish does not like to go on thick because it cannot hold its shape properly. When you approach 6mm you will notice that multi begins to sag under its own weight.
Solution: Let the plaster pull in more, and apply light pressure when laying it down. You also need to frequently discard of the excess plaster that has accumulated on the face of your trowel.
How to improve: Don't lay on thick coats, 2mm followed by 1mm is the way to proceed.
Question: What are tigers stripes?
Answer: Lines caused by a trowel that has been opened up too much when wet troweling.
Reason: When the trowel is opened up, you begin the process of scraping instead of spreading. If the trowel is opened up too much, instead of just scraping away minor lines you also end up scraping away hundredths of a mm from the surface. Even on a relatively flat surface, those hundredths of a mm will end up leaving cosmetic tiger stripes when the plaster dries (in most cases these stripes are not noticeable when the surface is painted).
Solution: Don't open the trowel too much when wet troweling and make sure the face is always wet. Only move about 12 inches at a time otherwise the water on the face of the trowel will run out and you then run the risk of tearing the plaster.
How to improve: Keep the trowel wet and work in small controlled fan shaped sweeps. Don't apply too much pressure and always overlap the previous sweep. A fast and smooth sweep is what you should be aiming for.
