PhilPlaster
Thought you had my back! OOOhhhh you bitch ;DNisus said:spread_the_flanders said:Nisus said:Why are you worried about the boards getting wet they will dry won't they?
It's only the same as plastering a ceiling where the walls are boarded isn't it?
It'll be fine just whack the boards up & plaster the wall, job done
The boards won't get damaged, and if they do and everything goes wrong well name is kirk johnstone ;D
OK - cheers!
you're right, the paper on the plasterboard will dry but maybe i rip it up with the float while working the walls when it's wet, that's all i was worried of.
But guys - OK. I'll do the ceiling first ok LOL ;D
Even if you do damage the plasterboard ceiling with your trowel
you will be taping & jointing the ceiling so you can use the joint compound to repair any damage,
but if you are that worried just take your time at the ceiling line, it'll be fine.
