Self Build
A semi finished house has 12.5mm plasterboard fixed directly onto sand and cement concrete block walls, which appear to have been straightened and plumb using sand and cement floated off. The boards are screwed on using plugs and regular screws. My understanding is there has been something like No More Nails adhesive used also.
Is this OK in the long term or do the boards need changing? With respect to dot and dab, timber baton methods etc. I am assuming there is no mechanical reason why these boards should be pulled off the wall before skimming.
These are internal walls. The external walls have insulated plasterboard using mechanical fixings.
