Old 1930s house to render
johniosaif
Hi, just viewed an old end of terrace ,which needs rendering , I do normal sand and cement work, if heroes for a colour render,will post it here.its hacked off perfectly. I would normally, soak it down ,give ita splatter coat with sbr ,so sand and cement slurry with sbr rather than sbr slurry brushed on.then a scratch with
Waterproof,say 4/1 sand cement,leave it 5 days or so then float with 6/1/1 sand cement lime , all hand applied, lovely big flank wall ,so a bit of work in it, three lifts on the flank. Probably put fibres in it also, isitworth wishing? I'd need one with 8mm holes ..cheers
Mono it John ,i looked at a small block of flats (only the front to do ) in Bromley last week ,if i get it come over and have ago
Not much experience in mono, but if you want to view this and give a price for mono to give him choice, I know him quite we'll, email me fitz8@btinternet.com or text07889413377
Thanks John ,but a bit busy ,sounds like the job is good to go ,it was a hot one today ,hard work and with a machine ,sod that handballing ,take my hat of to you my friend
I don't mind hand balling,once it's organised, once it's on,it's easy enough ish..
Starting a job the same tomorrow. Old dry dash hacked off back to old limestone substrate. My process will be,wash down,rendaid,fill out deep joints/voids 3-1 sand cement plasticizer. Fix on riblathe,scratch coat 4-1 sand,cement,waterproofer. Drydash finish 5/6-1-1 and apply stones.
That ain't going anywhere for many years
