NELA s*p*r*lex
Bagrat
after using nela s*p*r*lex trowel since they came out recently I've noticed on the butt end of boards they show lines where the boards join onto the other boards .my method of using the trowel is 2 cross trowels at the end of the gauge but I do lay on only 2 mil !my question is is it because I'm laying on to thin ? Or just maybe hitting to soon with flex any ideas very much appreciated thanks in advance .
2 coat then..i crossed over to the dark side on Friday and 1 coated a kitchen and living room and looked bob on but we did it properly in mixing a bag up layed all joints down with beads,casings etc then put a gud coat on..actually enjoyed skimming for once
Go on my man !!
Youl soon get used to using 1 big mix kitchy.
Soon youl be singing "now this looks like a job for me, now everybody just follow me...na naa na naa na na naa na naa naaaaaaaaaaa"
Go on my man !!
Skimming is still last job I want to do :)
Not the best pic but this room was 1 coat..70m2 kitchen..think I was sat down for half hour waiting for it to go off and domestic lads say we kill ourselves..i think if ur 1 coating tho it needs to be done properly I.e filling scrims,beads,door casings out 1st with a different batch..not sure which way Il go yet
Don't ever let me hear u saying u ienjoyed skimming again :cachetada:
The only advice I can give is its nothing to do with the trowel
I think that's fairly obvious by him saying its just on joints of boards If I've read it correctly..dsnt take Sherlock to work this 1 out
What a Mess ... :wtf:
Looks like a Big Pile of Poo ! :banda:
On the floor in the middle of the room :birras:
:bailando:
What was his wife like ??:birra:
No milf..was a old guy who's a multi millionaire by the way and he's trying to tell me it will take a day to do a 3 day job at least..wil have a nice surprise anyway wen I quote as cudnt care less wether I'm doing it or not as I'm subbing it out anyway
The ceiling was metal the builder left a couple of mil gap between boards of which I greased over prior to skimming .the ceiling once painted had lines coming through where boards met up . I only ever go over with the flex very late in gauge ! Just curious
Its the skimming sagging because of gaps then...
Too thin or excessive pressure on the flex , causing taking some plaster off the tapered edges. When you fill the gaps you should fill the tapered edges, not the scrim only.Gaps have very little to do with this, in fact small gap actually is better than none.
Is it only happening on the MF ceilings?
I'm not sure as once all work is normally painted I'm gone ! But was thinking to thin but maybe to excessive pressure ! Was thinking of going back to tried trusty mt ! You can't notice anything before paint looks always spot on !
2 much movement on joints.....ive been on some sites where the metal stud and boarding is fuucking horrendious.
And seems impossible to sort even corked the day before with adhesive.
Its either skimming sagging through the gaps or its flyny said..that hotel we are doing theres hardly any supports in the mf ceiling and havnt had this problem..we even told metal fixers why dont you put more in answear was dosnt need it lol..there problem not mine..some theories people come out with on here make me laugh..its sagging or wat flynny said
@Kitchy....been saying it and telling you and others for ages plasterboard once beads joints and door cases are bedded down only needs 1 good heavy coat!!!
You've seen the light son!... Now perfect it and your talking serious dough!!!
@Bagrat if having probs stop crossing your work early on always trowel up the joint rather than across the joint.
Would still put same on zolco..aint into that 3 gage stuff
I ain't putting 3 gauges on this week let alone in a day, got like 2-3m² to skim in a kitchen tomorrow afternoon after we ripped the old one out, so I can throw the tiles on Wednesday morning that will nicely do me and hopefully by Thursday I can jump on an exterior for a week if the scaffolding goes up by then
