Half time.
Casper
What’s the score with it? Anyone got experience of it? Good, bad ? Got some to try on a wall tomorrow
Neilevs18
It does work. But be careful how much you put in, especially if only mixing a small amount of plaster. Went solid half way through mixing with me before!
Casper
Bloke on Amazon reckons he skimmed a ceiling in an hour with a sachet and a bag of multi.
Damian plasterer
This ha ha
Casper
I’ve go a small wall to do so I don’t want to be writing off a half day. I’ll Chuck extra half time in the mix
paulf
Pointless, your not taking half a day to skim a small wall. Although knowing you you've probably drove 200 miles to get to it so that 20/30 minutes less settling time gives you the time to enjoy your prawn sandwiches.
Casper
Not just any prawn sandwiches.
Vincey
It’s good I think especially if you lay with same gear you’ll get it finished on the hour no problem
Vincey
Gear on then first flatten 35 minutes second 45 minutes cross trowel 55 minutes
60 minutes that’s it done
Steve Brown
I’ve used it a lot to save time on the last mix when I want to beat the traffic etc.
Like Vince says and you won’t go wrong, I find that you still have the same time to first and second coat using the same gear but it goes bang and sets just when you want it too.
Extra time on the other hand used it once on a big ceiling........ never again took about 4.5 hours til last swipe FFS.
