Mesh and bonding, it is easy enough and gives character to a buildingCustomer wants it curved, not stepped!
Recommend boarding or mesh??
Looking at glasroc f board, 6.5mm bendy as fcuk, also expensive as fcuk
It's a stair winder not a barrel ceiling as John suggested EML and bonding.Customer wants it curved, not stepped!
This was eml and bonding and skim,3 floors high ,
Cheers, not heard of it b4It's a stair winder not a barrel ceiling as John suggested EML and bonding.
Just a normal 8x4 sheet CNC'dLooks awesome
Eml & bonding it is!
Must say though zolco not seen that type of board b4 what’s it called?
I meshed my ass and it was a bugger to do but I came out . QUOTE]
Well said
I see, clever! Did u cut it, took an age I’ll betJust a normal 8x4 sheet CNC'd
Yes I did it, it's rapid, I cut 3 slots in one hit, and no dustI see, clever! Did u cut it, took an age I’ll bet
I'd be well proud of that, proper job!
It's so easy to do , just get it prepared ,bang it on, once you've done one ,you'll seeI'd be well proud of that, proper job!
Great advice pal, see through plastic? What for?Use 2/1 battens or metal stud (light ) to create the form work for the shape, put see through plastic on it ,fix the EMl tightly,no sagging areas , appply a coat of bonding (bonding 60 is great ) when it pulls in apply another coat of bonding ,create the curves to be easy to follow ,nice sweeps , when it pulls in,skim it , use plastic for the sharp bits as a smoothing tool, the s*p*r*lex are good for finishing
Stops the bonding falling throughGreat advice pal, see through plastic? What for?
Got ya cheersStops the bonding falling through
I've done a few but not as big as that, has anyone mentioned about putting little washers over the screws when fixing the eml? I find that helpful when I do them and flexi or plazzi trowelIt's so easy to do , just get it prepared ,bang it on, once you've done one ,you'll see
Yes, I do that ,I've done a few but not as big as that, has anyone mentioned about putting little washers over the screws when fixing the eml? I find that helpful when I do them and flexi or plazzi trowel
Is that you in the photo John? Handsome chap you are - who's the bloke on the left taking a piss or wanking?
No ,that's a chippy named frank, I used to call him handsome frank ,great chippy and a nice lad .no idea who's in the cornerIs that you in the photo John? Handsome chap you are - who's the bloke on the left taking a piss or wanking?
How did you board that John
When I finished labouring and broke free, I worked for a company in Essex (Toveglen I think they were called). My first job was doing stair winders for them - they paid £80 per winder, my first one took me two days (not bad, that was £8 a day more than labouring). I remember trying too hammer nails through the eml and then vibrating on the battens....what a clown I was!
