Maybe have to see . Didn' want to really. If there the ones with the trench for board to sit in might as builder to put em onCould you not nip in day before and stick them on?
Customer will be there with 2 kids. Should I bottle some upPiss in it!!! come on!!!! Bloody hell !! everyone knows that!!![]()
Hot piss!use hot water
nah just crack on, not at all inappropriate and don't you let her make you feel like a wrong'un!Customer will be there with 2 kids. Should I bottle some up
And you wonder why cats crap in your garden, you have a fetish for bodily waste young ladyHot piss!
If it's only a couple of reveals, why not use Pink Grip or summat like that?I.ll try that . Was tempted to use bonding and cement but tops steel
Not sure how far they need to come out yet. Plus builder will freak if I ask for summet else when there' adesive on job lolIf it's only a couple of reveals, why not use Pink Grip or summat like that?
Got one wall to go back to as waiting on bi folds to get fitted. Only bout 3 boards to skim but got to dot reveals on. Like builder so dont want to be charging him for day by having to wait for reveals to set. Any way to make adhesive set fast .
Well it is his fault you can’t do them, out of sequence and all thatNot sure how far they need to come out yet. Plus builder will freak if I ask for summet else when there' adesive on job lol
Mate don’t worry Just charge for the day. Where else you gonna go and make your days money up?Got one wall to go back to as waiting on bi folds to get fitted. Only bout 3 boards to skim but got to dot reveals on. Like builder so dont want to be charging him for day by having to wait for reveals to set. Any way to make adhesive set fast .
Use dry fix foam
Insta stik I think it’s calledI use the foam adhesive for reveals if that's all that has t be boarded. It's solid in 15 minutes and no mess from mixing etc.![]()
Ive used it on reveals ect always worked well for meThat's the stuff. It's quite expensive for large areas, but for little bits that you don't want to be hanging about all day for it's ideal.
I've used it on reveals, but also things like blocking up an extractor or boiler vent hole. Exp foam in the hole to block and insulate, chip around it to expose the brick/block, stick the board and patch/skim the wall.![]()
Half time isn't available in the Chelmsford Wickes, well not unless you want to order some in special.Foam the f**k**s on, get some 1/2 time for your finish (now available at wickes apparently) and be in the van by 11.30...or the pub!![]()
Hmmmm . Well they have asked me to do bit more . (Behind builders back, I know dont like to). But if I stick reveals on then go do little ceiling .How far away is job? Could you mix in back of van before setting off
