Emmi Thornton Crowley
Hi,
Recently had our house rendered onto new breeze blocks so the surface to render onto was new! However when the sunlight shines on the render (or lighting is switched on outside), you can see visible uneven areas that look worse in some areas.
The front looks the worse as a scaffolding frame on wheels was used and moved along as the builder rendered. The front was done in stages rather than one go; therefore it was done with different mixes.
However the side of the house was much better as a full length free standing scaffolding frame was used.
It was in the summer when it got rendered so the sun was on it and as a result there are also some small cracks that have had to be filled!
The render said he would do the front of the house again after we complained (he could also see the faults) but we decided to just get it painted and see if that helped.
In normal light it doesn't look too bad but when lit up or in sunlight it looks terrible in some areas!
Any ideas?
Any ideas?
