Oh dear ,Hi,
I've moved into a new home and the plasterboard joins are very obvious.
The boards seem fastened the the studs well but as you can see the seam is obvious.
What has gone wrong and how can they be fixed?
View attachment 14745 View attachment 14746 View attachment 14747 View attachment 14748
normally happens with paper tape
How funny they are raving about it on the other thread lol
What's 2mm of gypsum skim gonna do to better the acoustic properties of the wall?It looks like a 'tape and board' job, I would suspect many of your rooms have been done this way. It does look to be a pretty poor job. My advice would be the same as already mentioned. Take the paper off, scrim the joints and skim the wall.
Dry-lining is popular now for speed and the tape and joint system advertises walls ready to paint with skim.
The problem with Dry-lining is it does nothing for 'Acoustics' in a property, literally making the walls paper thin. If you have the time and money it might be worth your while to get all the walls skimmed.
Never done 2mm, 3mm makes a difference thoughWhat's 2mm of gypsum skim gonna do to better the acoustic properties of the wall?
5ml,........5ml.......that's 3 coat work!!!!!....And here I am just trying to get used to being a one coat sponge monkey.....pffftThat job will probably take upto 5mm lol
