tyrolean finish with parex
clivo
Hi , anyone done a tyrolean finish with parex using a ritmo, what speed setting, water, nozzle etc ? or is it easier to just put it in the flicker gun :rolleyes)
I've done a fair bit of tyrolean with the ritmo, using the texture gun and big compressor, but with the air turned down low. I have always premixed the gear and poured into the open hopper and have the speed around 2.5 / 3
pretty much as wezly says. the texture gun is for texturing and the bigger compressor will give you a desired pattern. very quick
so it wont do it with the onboard compressor ?
I've used a refina mortar gun with hopper using just the centre nozzle and kit and 1 tool compressor. I used k1. You need someone with you hopper up cos that compressor doesn't half push it thru
When u say texture gun. Do you mean the swing gun I have or another gun like the new one that does all things to all men
The one that the swing gun will connect straight to. I'm guessing I just use the r/s with a reducer?
