Richard 91
Hi guys I recently bought a carbon steel trowel (spring Steel) what’s the best way to get it razor sharp as I’ve heard they can get really sharp
Or floor screedsWas a time a skimming trowel wasn't a skimming trowel till you rendered with it for a few years first!
Use it daily for 2 years!!Hi guys I recently bought a carbon steel trowel (spring Steel) what’s the best way to get it razor sharp as I’ve heard they can get really sharp
Problem with that it's not really molded to the individual if ya get me back when you was rendering or whatever it kinda gets its shape naturallyYh I just skim really what about them stones are they any good
You can get a brand new trowel razor sharp in no time if you buy good quality whet stones, I've got a set in my masterbatorium (Hi guys I recently bought a carbon steel trowel (spring Steel) what’s the best way to get it razor sharp as I’ve heard they can get really sharp
That was the way, but also back then loads of float and set. Trowel for rendering, one for plastering and the finishing trowel.Was a time a skimming trowel wasn't a skimming trowel till you rendered with it for a few years first!
You don't use a trowel I thought you used a shovelI can break in a skimming trowel in 2 weeks
floor scraperYou don't use a trowel I thought you used a shovel![]()
1 week if you did 2 coats @essexandyI can break in a skimming trowel in 2 weeks
Loads to choose from, the cheaper ones wear out quicker, you can get double sided ones coarse one side smooth on other higher the grade smoother the grain 800/2000 works wellLooks great what stones to you have and what grades were should I buy them from also what’s the best techniques when using stones
Blokes an absolute w**k*r John. Setting a poor example to the yoof.1 week if you did 2 coats @essexandy
Got one,absolutely useless.![]()
Trowel Sharpener
Extend the life of your trowel. Eliminate small nicks and dull edges. Center channel to keep a straight edge. Handle keep hands out of the way of the trowel. USA with global materialswww.krafttool.com
Fair play I haven’t used one thanks mateGot one,absolutely useless.
Hi there when you get a chance can you film you using your whet stones love to no the right angle a techniqueLoads
Loads to choose from, the cheaper ones wear out quicker, you can get double sided ones coarse one side smooth on other higher the grade smoother the grain 800/2000 works wellView attachment 60965
