A magnet. Best couple of quid I've ever spentAnyone use and can recommend a good stud finder . I over board ceilings most days and would like to make life easier rather than using my estwing stud finder .
How you gonna find a timber stud with a magnet ? Especially on a lathe ceilingA magnet. Best couple of quid I've ever spent
Screws going into the stud. Doesn't work on lathe ceilings but 9/10 of ceiling I overboard are plasterboard. Lathe ones I just tap holes down the sideHow you gonna find a timber stud with a magnet ? Especially on a lathe ceiling
Asked for that didn’t II’m here
I’m here
Will it pick up nails in lathe ceilings?Strong ring 50mm Neodymium magnet.
YesWill it pick up nails in lathe ceilings?
I do a lot of overboarding too, I have tried the strong magnet method but end up getting paranoid and going back the the lath hammer method. I am much cleaner than I used to be, I hold a bucket under to catch the crap my aims a lot better .Anyone use and can recommend a good stud finder . I over board ceilings most days and would like to make life easier rather than using my estwing stud finder .
What is wall a bot ?I do a lot of overboarding too, I have tried the strong magnet method but end up getting paranoid and going back the the lath hammer method. I am much cleaner than I used to be, I hold a bucket under to catch the crap my aims a lot better .
Have you seen the wall-a-bot?
I love the idea but don't think it would work on L&P
Wall scannerWhat is wall a bot ?
I always use chalk line mate it’s loads easierWe just find 1st joist then try roughly every 16" with a long screw.
Dont see the need to even use a hammer or piss about with string lines personally.
I just find it quicker personally bud, I can find joists and ping lines in no time then boards go up pretty quickWe just find 1st joist then try roughly every 16" with a long screw.
stud buddy not bad but hit and missScrews going into the stud. Doesn't work on lathe ceilings but 9/10 of ceiling I overboard are plasterboard. Lathe ones I just tap holes down the side
