Stick beads on with glue gun?
Wayners
With talk here about sticking beads on with tape I had a thought yesterday when fixing new rope to cat pole. Would a electric glue gun work to hold beads? 240v and 110v and battery available. Sticky with a quick setting time. Tempted to try...
D
Deleted member 32554
Guest
Yes good on dry and can pack out , I'm not into it , have you tried contact adhesive for tight beads on board
D
Guest
To me there's a fundamental issue that I can't grasp , why do people think their are holes in the beads lol , I get it that people want to do as much prep as they can and don't want to push them into the first coat , especially a wall with multiple windows and one coating , am I seriously the only one to do this as standard practice
zombie
Yes your F*****g mad!!!
tapit
think so, need vid
tapit
Do you mean as in first coat of two coat skimming and if you do you must leave first coat a while to stiffen up.
If so that is old school and most spreads now go straight on with second coat.
D
Guest
Agree , I'm not a skim monkey , yet , lol but those who staple , OR tape will still have to be careful not to knock out of alignment , a two coat with firming first coat is much stronger
The holes are their for a reason , why do you think ,
D
Guest
Which is why I suggested spray the bead with contact Addy , if bead doesn't need packing
tapit
ok, got you now. yes your way is probably best but too slow imo for a lot of jobs.
you would not shift a bead that has been taped it is held solidly unlike staples.
the holes in bead can be filled with plaster from either side ie.pressed onto skim or skim pressed trough bead.
Thats why my tape has holes, so simple like me.
Vincey
Am skimming tomorrow will time myself when sticking on thincoat beads to window reveal with half a bucket trowels worth of skim even now am thinking gonna be under one minute
D
Guest
Don't think that a plasterer who leaves first coat to firm is wasting any extra time , with that technique you just put more walls on ,
tapit
I basically stick them on with first coat of skim and give them a little tap as lay on second coat
ok, so similar to havagojo. must have to go carefully around them while trowelling though.
Is the little tap to line them back up?
Vincey
Just to make sure they are solid and correct, I use my snips to tap as they slightly heavier than trowel
Wayners
3mm stop beads I've caught at the bottom and popped off a dried coat. Clout nails end up in my or customers car tyres. I don't use because of that. Seems no matter how careful I am with them.
D
Guest
Can agree with stop end , care is needed and accidents happen
