I don't even know what you mean tbh.Dog s**t
Laminate with beading
Your welcome
What's a shadow gap bead? Can you not achieve the same thing with an edge bead and leaving a gap?
This type of shadow gap bead would be better IMO.View attachment 55007 Also available in plastic now, mainly for drylining. Means you can put it against say door frame and get a fixed constant width without messing about with a spacer etc. with a stop bead. Also it hide a crappy background/mastic/holes etc. & allows you to wipe it out clean without ruining the wet edge.
This one in the pic looks a bit wide for me, prefer narrow so it creates a shadow (Duh). Sometimes paint the channel black to create a false shadow. On your's it'd get painted white, but I like and prefer your angled edge, v. nice.
That's the ticket! Never once thought to take photos of the stuff i have doneThis type of shadow gap bead would be better IMO.View attachment 55032
It'd be a boring website without pictures.That's the ticket! Never once thought to take photos of the stuff i have done
No Skirt? Always wanted to see that. What floor covering? Any good?
Like a stop bead but with a uniform channel. 10-15mm I think. In my opinion it looks smart. I've done whole houses with them around windows, doors etc. No arcitraves or skirt whatsoever
C’mon now Paul. There’s no need to put a picture up of your own shite work mateCan't beat the @Casper African rustic finish, I'm sure you've got another name for it.
WTF are you? A picture framer?This type of shadow gap bead would be better IMO.View attachment 55032
Ah know, what am I like, couldn't burn ma neck with a blow torch.C’mon now Paul. There’s no need to put a picture up of your own shite work mate
That was a house with shadow gaps around every door and bottoms of the walls.WTF are you? A picture framer?
You couldn’t get a red neck at a bonfire.Ah know, what am I like, couldn't burn ma neck with a blow torch.![]()
Not really the bonfire type.You couldn’t get a red neck at a bonfire.
Nope.Don’t geez yer pish
It's very, very time consuming fitting them correctly.I was asked to quote a full townhouse that had those shadow gaps.
Why's that? They're not too bad to work to. Getting the fitting right is the faff.These were already fitted when I did the quote. I just walked away
u Should of took it on. no skirting or cove for u to s**t up lol.These were already fitted when I did the quote. I just walked away
Haha haha you’re cracking me up hereu Should of took it on. no skirting or cove for u to s**t up lol.
Whats the problem with the fitting then?Why's that? They're not too bad to work to. Getting the fitting right is the faff.
Fitting them around door frames isn't so bad as you're just butting them to the frame. Obviously the mitres need to look neat and tidy. Around the bottoms of the walls takes time to make sure that they're dead straight, level and the correct height, allowing for the different floor coverings going in different rooms.Whats the problem with the fitting then?
Getting the internal and external mitres to look neat is quite a precision job for a rough old spread.
Says someone who has clearly never fitted them.a good starting point is 45 degrees
And a bubble
Thanks, I can see that being a challenge especially on an older buildings.Fitting them around door frames isn't so bad as you're just butting them to the frame. Obviously the mitres need to look neat and tidy. Around the bottoms of the walls takes time to make sure that they're dead straight, level and the correct height, allowing for the different floor coverings going in different rooms.
