Solo lime finish
S a plastering
Has anyone used this got some too do over warmshell insulation which is stuck on top of nhl 3.5 not really used the finish before just wanted a run through thanks
l*m*-g***n solo?
Iv used a fair bit, it’s hard work drags like f**k.
Best way I found a tight coat then drop back and second coat, I use a 600 spat to flatten in then 16” float sponge then last off hard trowel
l*m*-g***n solo?
OK cheers I'll give that a go it's on top of warmshell which has to be fully meshed in first pass
Think that was it. . Not 100 percent but think we 2 coated with it .
That’s what Iv used a few times now usually over nhl3.5 scratch but also gone over ultra base coat, never had problems with it bubbling just give background a really good soak
Yea that's the one this is grade 2 listed so on stonework is nhl3 with grit sand then then a breathable 2 inch thick fibre board with the solo on top
