Skimming straight onto wallpaper
D
Deleted member 21440
Guest
You can go over wood chip with airless plaster. Not a product used much though
The_one_coat_wizard
Can it be done?
Wouldn't the dry wall adhesive really help the multi finish stick to the wallpaper and the triple pva will make sure that wallpaper is glued to the wallforever
djfleming22
3 coats of PVA on wall then make a zombie mix with a 2 litres of PVA and teaspoon of sugar and 2 bags and give it A BIG STIR that should do it
imago
Anybody heard of this method?
My mate told me it can be done and does it regularly when house bashing, he said the key is to triple pva the walls then put scrim down any wallpaper seams using a 50/50 mix of board adhesive and multi finish
Thoughts?
Surely you'd be better covering the existing paper with lining paper? Put it on with a single coat of PVA (saving two coats) and the lining paper will act as a key to skim directly onto which will save buying baord adhesive as well as multi.
The_one_coat_wizard
Ye my mate doesn't mind cutting a few corners, he openly admits he has never used skrim before and argues that he will be paid before it cracks so it is a waste of time
The_one_coat_wizard
Believes that customer rentetion is a myth in the house bashing game and its very rare you do repeat work for a single person, unless your working for contractors then and only then will he will use skrim
johnzo
Thoughts?
god the fact that you are even asking this question baffels me .and as for your mate has he a van or just a horse ,has plastering come to this it seems to me some lads will do anything to turn fast money where has the pride gone
