Thermal properties, cut easier, lighter and quicker to lay. Any suggestions on the rendering?Can i ask why you chose to build it using celcon blocks in the first place?
Rendergrip the wall, that wall isn’t tied in properly such a bodged for a little job can’t believe my eyes tbh,
Have you used rendergrip on celcon blocks before?Rendergrip the wall, that wall isn’t tied in properly such a bodged for a little job can’t believe my eyes tbh,
Loads of timesThanks for your reply. Have you done this before? This was the method I was hoping for.
What the actual f**k is going on with that block work?Evening all,
I have asingle story building with celcon blocks that I need to render. I’m thinking my options are either making a brush on slurry of sbr, sand, cement, water, wait to dry then scratch coat as normal.
Or would galvanised steel mesh be a better option?
or am I well out and someone here has done a few of these and found something that works? Ratios would be great.
Thanks.
ps, the building has had an alteration after completion hence the odd block work to the left of the door. Not looking for comments on this. Thanks again.
Do you have an answer to the question about rendering the blocks?What the actual f**k is going on with that block work?
I might have.Have you used rendergrip on celcon blocks before?
So did it work?I might have.
MaybeSo did it work?
Yeh the blockwork is level and plumb so it doesn’t matter how it looks when it’s being rendered.Plenty of suggestions and methods there!
Looks like the block work done in the dark or pissed
Probably a board skimming site monkey.I might have.
Only pulling your leg babes! But ya gotta admit if the back ground isn’t in the best of states or done properly it’s all coming down to the person who finishes it, YOU.Yeh the blockwork is level and plumb so it doesn’t matter how it looks when it’s being rendered.
plenty of suggestions yes. Some people saying just render as usual with a spray down before. Some saying rendagrip. Some saying slurry coat before.
it’s a shame that there’s so many plasterers on here who actually have no idea and would rather pick faults with everything else.
I think I’ll go with the slurry and render as usual. The wall on the photo is only around 4sqm so not a big deal if it goes wrong.
Iv ordered the Refina hopper btw my back went so It might help outThere's two sides to this giving advice to non forum contributors and DIY section newbies lost interest unless there well-known members
You sure we shouldn't get professionals in love? Na don't worry, how hard can block work, cutting abit of plastic and rendering be?Evening all,
Thanks.
I’m happy to finish it....I’m just concerned about suction control and the rendering actually staying on. That’s only reason I asked in the first place if someone had experience and found a way they’d always use.Only pulling your leg babes! But ya gotta admit if the back ground isn’t in the best of states or done properly it’s all coming down to the person who finishes it, YOU.
The plastic wouldMy have cut right because of how thin it is. The blockwork doesn’t matter as it’s being rendered. The render will be fine as I’ve done it many time’s...just not on celcon blocks. Again, no answer given.You sure we shouldn't get professionals in love? Na don't worry, how hard can block work, cutting abit of plastic and rendering be?
Well if you're sure...
It will come in handy for terylene as well no more winding mateIv ordered the Refina hopper btw my back went so It might help out![]()
Glad Iv got it now my arms feel mush better just looking at it, the gentilin is on order to,It will come in handy for terylene as well no more winding mate
That little setup will come in that handy guaranteed you won't regret it, the gentilin cracking little compressorGlad Iv got it now my arms feel mush better just looking at it, the gentilin is on order to,
Well you clearly know as much about me as you do block laying or rendering.Probably a board skimming site monkey.
Have you? What’s your method then? That was all I asked and it only requires a professional answer. I wasn’t referring to you on that comment.Well you clearly know as much about me as you do block laying or rendering.
Just for the record I've done acres of rendering on to Celcon/Thermalite blocks.
Good luck with it.
View attachment 51522What the actual f**k is going on with that block work?
Good luck with it.
Yes use the proper materials next time . If you had used concrete blocks you would not be in this situation .Thermal properties, cut easier, lighter and quicker to lay. Any suggestions on the rendering?
Proper materials? Celcon blocks can be used externally and even for footings below dpc.Yes use the proper materials next time . If you had used concrete blocks you would not be in this situation .![]()
The blockwork is plumb and level. Doesn’t matter about the look as it’s being rendered. How about answering the question?
Park life.....Proper materials? Celcon blocks can be used externally and even for footings below dpc.
You could give me an answer but I think not people on this forum are very poor plasterers who only skim on new builds or self employed who can’t make it work. out of this whole post I’ve had about 2 decent answers.
I think thats down to nobody here really having an proper experience.
Why would be happy to give away our knowledge for free?.i don’t know if I believe it anyway. If a question was asked on here and you were highly experienced you’d be happy to answer and show off your knowledge. Im going to slurry and dampen down before rendering as usual. This will create a good bond and should control suction.
I’ll upload a photo once it’s done so you board skimming cscs card holders can have a look. Cheers.
That sounds like when you ask a kid a question he doesn’t know so he says why should I tell you. I’ve contributed to this forum plenty of time’s over the last 6 years and never thought I needed paying for it. It was a simple question about what’s the best process.Why would be happy to give away our knowledge for free?.
Is this your job as in built it etc?Proper materials? Celcon blocks can be used externally and even for footings below dpc.
You got plenty of sensible answersThat sounds like when you ask a kid a question he doesn’t know so he says why should I tell you. I’ve contributed to this forum plenty of time’s over the last 6 years and never thought I needed paying for it. It was a simple question about what’s the best process.
very surprised by the immaturity.
