Hi all - thanks in advance for any advice you can offer.
I'm currently ripping out a bathroom and have found a problem with the wall behind the old shower. It is thermalite block to which about 20mm of sand/cement render has been applied when built. It has clearly failed in the areas I've removed, but I think is more solid above the door and potentially towards the stud wall (see photos). My intention initially was just to get the whole room skimmed (a dark art I will never understand so was going to get someone in to do that in a day), but now looks like I need to make the wall good. Few questions if that's ok?
Should I strip the whole lot back to the thermalite (upto the red line on the image above the door) and dot/dab or could I patch the failed area if the render is sound elsewhere?
If patching - what should I use?
If D+D, I'll obviously need to match up to remaining render so would that work (approx 20mm depth)
There is a shower going in that corner so presumably MR plasterboard. Ideally I'd use aquapanel under the area to be tiled but am I correct it can't be dot and dabbed and would it lead to issues with 3 different substrates on the same wall?
Any advice gratefully received.
