Render on timber?
BobbyJack
Built a garden room. Wrapping walls and ceiling with 8x2 T&G moisture resistant floor sheets. Roof is getting GRP. Originally was going to clad the walls with timber but our peg now likes render. So can render be applied directly to the wood with a grit primer and mesh or is it a no go. Open to suggestions. If it can be rendered does anyone fancy giving a price. In manchester
That looks like it is going to be a nice space
raggles
If you haven't already looked, I would take a look at Marley concrete cladding or composite cladding. Both come with good colour fast guarantees (over 20 yr if I remember right) and no danger of future cracking.
Runswithscissors
hi
feel free to drop me a mail and I will send you some details of how to correctly apply a render carrier board to a timber frame
As Owls says above, you need a sheathing board and breather membrane to the current structure. The vertical battens tower create a drained and ventilated (top and bottom) cavity before a tender carried board and thin coat tender
Timber frames need to breath, to allow moisture to not form in or on them, which will cause the structure to rot...
drop me a mail to richard.lord@knauf.com and I will send you some details about Knauf Aquapanel Exterior to help
good luck
Richard Lord
Knauf
07918766577
