Capital spread
I don't use this site myself but as its gone very quite I had a look couldn't believe some of the budgets .
One guy wants you to take down an old ceiling, take a cast of the original coving, replace the ceiling with soundblock then replace the coving about 15m2
Lets break that down
Sounds like its a lathe & plaster ceiling very dirty seal and sheet up, replace with soundblock and skim plaster thats not to bad.
Take a cast of the coving, no problem if the fibre shop has the pattren, if not make a mould to match and run 4 or 5 lengths of coving.
Go back to the property and fix the coving and as its fibre its all got to be screwed up
My point is would you do that for under £1000.00 or am I just to expensive and thats why I got no work
