If you are looking for technical specifications to render onto insulation / boards / block / & other substrates as required using a thin coat render please forward any queries to me and i should be able to assist you with this,
Silicone TC is a ready to use organic resin render which is applied to provide a low maintenance textured finish. It is available in different textures and a wide variety of colours. Prior to application the substrate should be primed using Primer TC.
