Hi all, Slight problem with Krend last week. Did one wall and basically rushed rubbing it down with the I bar. Had a patch appear with the scratch lines in it. Cut some back and patched it but it looks s**t , it is a wall with 2 doors and 2 corners on it so if i re-bead then will have to return around the corners. I was going to strip all the topcoat back and redo , any other suggestions ?Thanks
