K rend Mono
Elite exteriors
Thing is our crew spent £10,000 on this setup
From p1 you expect it to spray fkn anything other machines can for that price. Struggles with 20m hoses most of the time. So many jobs with correct setup to the t there has been problems. No wonder everyone on here slates the mtech and seen so many people who have moved to ritmos from mtech. We got 2 pallets of mono on this job that don’t like the “smaller” machines. However we saw a crew down the road spraying 3 sides of a bungalow using mono with a ritmo
If they were spraying k-rend with a ritmo they were more than likely using a soft stator I know a few people that also say the m-tech struggle and moved to pft
GrisledaBlanco
We have sprayed it, I haven’t stated it cannot - we would like the material here with you to run it through your machine with you.
Thing is Ryan it’s a 3 hour drive to get to you, a day lost, fuel and you also mentioned bringing up to 15 bags of mono. Shouldn’t it be up to either you and krend to send somone out to site? We’re the paying customer here.
Plasterers1StopShop
I appreciate it’s a 3 hour drive, however, it is also an opportunity for you to learn and resolve the issue, meaning you don’t get wasted days. The information you’ll learn will also be beneficial for other days.
I mentioned to your boss, 15 just in case more testing is needed, but towards the end of the call mentioned 6 would be sufficient.
No, it isn’t up-to us to visit you on site, you and your boss have both stated that the machine has preformed very well with other materials so it isn’t a machine fault - also, we have always stated with all customers, coming to us is the solution, this isn’t something many other manufacturers/dealers would offer. We are even offering you to visit us, for free! You can always call KREND out to site, however a sales rep won’t be able to help with machines or even application.
GrisledaBlanco
I understand that new products will always be released that maybe aren’t suited for certain machines but you have to understand the frustration here Ryan. Spending thousands on a machine and then to use with a material that’s designed for machines that doesn’t work. I’m not here to cause any arguments know what I mean and appreciate your offer but unfortunately it wouldn’t be free for us. Would end up costing hundreds.
GrisledaBlanco
You know, we got KREND telling us it’s the machine and to mess around with the parameters that andy strictly advised against and we got yourselves saying it’s the material.
Elite exteriors
K-rend does go through machines though not a problem for the g4 and also with the right R&S it goes through the ritmo you'd be a fool not to take the offer here you will definitely learn something about the machine you are using it could even be you at fault but you'll never know if you don't go
Knowledge is power buddy
Plasterers1StopShop
My immediate question to KREND is what Parameters? Why should they need changing if our other material requires it.
These should NEVER need to be altered and should only be done so by qualified technicians.
I completely understand your frustration, trust me, I’m sharing it. It will end up costing you more not getting the issue resolved. The option is always there mate
GrisledaBlanco
You’ve also had over 14 pallets through your R/S and awaiting a new one. It could even be down to the R/S being worn.
Yeah we’re awaiting delivery it’s due tomorrow and we will have another blast at it but you know what mate if that doesn’t solve the problem then we will give you a call to arrange the day because we just wanna get to the bottom of it.
Elite exteriors
The gear would be like piss if the r&s has gone you can test it with a pressure tester
