Insulating Victorian walls
Jbeesy718
Hi after a bit of advise
I want to try and insulate the downstairs external walls of my Victorian house it has solid wall construction brick exterior which we get a bit of condensation on in the winter months not a lot just the odd bit behind a side board and storage box. I’m thinking maybe gypliner some insulated plasterboard in front of the external wall but I’m unsure if I’ll create more problems by creating a cavity anyone have any experience doing this or could point me in the right direction of someone who would know. Thanks.
The insulated studs minimise cold bridging. You could do the same with normal studs but would require an overlay of PIR board.
Forget it you loose too much room IMO all plaster off skirting sockets need to be brought forward window reveals will be tricky no depth on frames , poss loss of coving
Your problem is cold air meeting the warm
Your welcome
insulation to walls, silver tape to joins. battens across insulation then plasterboard screwed to battens.
If you can use Instastick foam and bond the insulated board directly to the existing
I used Instastick to fix 25mm celotex then stuck 12.5mm over the top on my house. It is now so cheap to heat. Wickes cheapest 25mm celotex type insulation is £23 +£8 for plasterboard . Bargain and thats without the 10% trade discount.
Your welcome
Seen these paints another brand claiming to do the same. Have you experience with the paint or just a recommendation? Seems to good to be true to me?‍♂️
Thanks going to look into iwi.
No gypliner unless you have a massive house
D + D insulated plasterboard, the more expensive ones perform way better. Although the basic still does a job.
Wickes' version - around £40 right now - does a bloody good job for the thickness.
House isn’t massive but could lose 70mm either side of it helped with efficiency of the house and reduce the possibility of condensation. Just be worried about moisture between the pir and brick wall as there won’t be any ventilation.
Did you do this on your own house? Or know if it’s resolved the issue? Just a little concerned moisture could form between the pir and brick wall, run down and cause damp at floor level.
Yes have had some renter with issue cottage
Solid walls same mould near furniture
but works put your hand on wall when dry & then untreated area you will get how it works
The stuff dries a bit orange peel but can decorate over with your choice
Worth a punt @ £70 on your situation
your welcome
My own house, we had damp issues. It had been injected but that's a waste ot time as any guarantee is not worth a w@nk.
Yes likely external ground too high & bridging & either or cavity full or solid construction
Rising damp is another unicorn
your welcome
your welcome
Think the previous owners have used this upstairs in the master bed when I stripped the paper it looked like orange peel. Thought it was an oil based paint like zinsser so I ran over it with a drywall sander Thinking the paint might not take properly‍♂️
I wouldn't worry so much about condensation.
The board (insulation) slows down the transfer so massively decreases the chances.
If you have moisture present (check with meter/tester now) through possible damp (rising or penetrating) obviously address that first and make sure you're bone dry before committing to the board.
Remember that stuff plasteronestop were sponsoring that was troweled on about 1mmm and had plastic bead technology? You had to go on a training course.
Or put a damp proof membrane on first
