Rossi46
Found a strip of sheet steel in a builders merchants a couple of weeks ago. 1 metre X 120mm by 0.5mm. When I saw it I instantly thought I could make something of it. I like fabricating things and pissin about.
Got a couple of worn out MT's that I don't throw away and keep them in a box in the lock up. Took a 14" out and cut it down with a steel cutter on an angle grinder to the same size of the tang base on a REFINA s*p*r*lex.
I cut the sheet steel down so the margin was the same all around the trowel base.
Buzzed the face of the trowel handle part, buzzed the face of the sheet steel then mixed some super strong resin and stuck them together. Bit of pressure for 4 minutes until it bonded. Buzzed the edges down to round them off a bit and I 've got myself what I'd describe as a Mediflex!!
I kid you not it's absolutely mint! Trowels lovely! It cost me all of about £6!
I'll be using the rest of the sheet to make an 18"er at absolutely no extra cost
