spunky said:its the spec ive done it before exactly the same
nick0412 said:if u read a bag of hardwall it says doesnt stick to plastic. plus its for high suction. bonding is for low suction ie plastic concrete etc
exactly you cant plaster that in one it does slump weve done basements in this but dabbed it if your going to solid plaster it scratch coat on with bonding let it pick up then either top it with bonding or hardwall then it will be finesprayit said:on the subject of how to plaster it the scratch coat layed on about 5mm and allowed to set provides a rigid base with a bit of suction. If you can put some more fixings in any loose bits it will help.
oasis said:frist time round cost £1500, then this time around £600 for damp man 2 fix and i charged 860 to hack off the old lime lite at 1.4 and bond back up, skim the living room (double size living room)
sprayit said:wasn't the original question about how to best tackle it who cares whats causing the problem . If you got any sense you will do what you're asked and say nowt unless you want to be involved in the callback. ooo
oasis said:im not sure i will have a read of the report
oasis said:was my job, we found damp, i called damp guy, let him deal direct.. damp man said it failed cuz thye used lime lite and not s&C as it said ON THERE SPEC! had an injection and a S&C spec, the guy couldt be assed to Chase it all up as it was over 6 years ago..
can tell were all bored 2day! iv been 2 work doing my first coving job 2 day!
flynnyman said:oasis said:frist time round cost £1500, then this time around £600 for damp man 2 fix and i charged 860 to hack off the old lime lite at 1.4 and bond back up, skim the living room (double size living room)
Any idea what is causing the damp?
irish_spread said:flynnyman said:oasis said:frist time round cost £1500, then this time around £600 for damp man 2 fix and i charged 860 to hack off the old lime lite at 1.4 and bond back up, skim the living room (double size living room)
Water
oasis said:ok here is teh other sizeof damp wall..
here is the crappy thing flexing after a tight scrach has dryed out
here is a vid of it flexing
https://www.youtube.com/watch?v=ggZ2YH7Uzw4
and here
https://www.youtube.com/watch?v=KXxyFHBrVko
oasis said:yea stev show us . i started off with a nightmare! couldt get the corners to look good even dow i was using a metal coving triangle thing, after getting a mate 2 take a look it turned out i wasnt cutting the agnles rite, just needed to take more time and expect in an old house that the angles wouldn't always meet tidy so have to step it back abit and fill them in with adhesive. looks ok now.
just a big more stress at first! been a reali stressfull week in all! so much that even in my sleep iv been grinning my teeth and chewing my jaw so bad i cant even eat! wot a prat
nick0412 said:oasis said:yea stev show us . i started off with a nightmare! couldt get the corners to look good even dow i was using a metal coving triangle thing, after getting a mate 2 take a look it turned out i wasnt cutting the agnles rite, just needed to take more time and expect in an old house that the angles wouldn't always meet tidy so have to step it back abit and fill them in with adhesive. looks ok now.
i think the metal triangle coving things are crap. i think mitre boxes are much better
