Do you know how much the asbestos test cost?Great advise and and had someone come round to test if asbestos in it all clear. Using this bond in stuff from selco green stuff hopefully ready to skim in the morning .. does the finish hang a little on this stuff ... normally I over board this is the first time I skimmed on this stuff ..
Haven' got a clue I work for a building / insurance work company so they deal with it . How much is it . ..Do you know how much the asbestos test cost?
Really any good?.? None sold about near me my way?..Unifinish![]()
There's a reason for thatReally any good?.? None sold about near me my way?..
I put about 8 handfuls per bag.. I'm putting to much thenI put about 2 and a half handfuls with bag of multi.. noticed the diffeent big time
It’s a plasterers saviour.Wtf is a zombie mix
Try 2 hand fulls you notice the difference and can tell it' in there . That' for sure.I put about 8 handfuls per bag.. I'm putting to much then
(Few handfuls bonding thrown in first coat sssssssshhhhhhhhhIs it adhesive in skim . We went through a faze with it but don’t bother anymore . Might be because it’s winter but other then it hanging longer what’s other use to doing it
Bonding as in backing coat or board adhesive(Few handfuls bonding thrown in first coat sssssssshhhhhhhhh)
BackingBonding as in backing coat or board adhesive
To speed it up . Never thought of useing this on smaller ceiling.Backing
It actually slows it down a bit but top coat like skimming over butter on artexTo speed it up . Never thought of useing this on smaller ceiling.
I did a artex ceiling other day and gave it three coats of pva after i had scraped it as i just knew it was gonna pull in .ceiling was bout12ft x 24ish . I mixed extra for first coat and just kept dropping back n keeping it flat but by second coat which hung you could of said I had all eady gave it 3 coats. Come up a treat but is it bad practice. Plus I was f**k*d and relised why I always get lad on large ceilings with me.
A
Confused . Guess it' because I always put a bit of skim or cement in to bonding to speed it up . Is it the same a putting board adesive in skim thenIt actually slows it down a bit but top coat like skimming over butter on artex
I've never put adhesive in skim. Bonding alone slows it downConfused . Guess it' because I always put a bit of skim or cement in to bonding to speed it up . Is it the same a putting board adesive in skim then
