fibretape
The Hobo
any one having trouble with novipro tape its doing my head in outside edge sticking to roll when pulling off thru 2 out today fcking shite
madmonk
That novipro is fccccin shhite mate i chucked all mine in the skip when this builder got it us seems that jewson sell a lot of it
The Hobo
that's where I got it they didn't offer a replacement so I will just take it off the bill fckem
The Hobo
We're using this now. Nice and sticky and seems decent quality. Obviously can't actually be made by @BritishGypsum otherwise they'd have f*kd it up.
your right there andy just doing an overskim with multi tearing away from base all the time pva applied day before so not sliding on that feels more like clay than plaster no fine grit at all /seems like st gobain got us all f**k*d
essexandy
The Lake Governor
your right there andy just doing an overskim with multi tearing away from base all the time pva applied day before so not sliding on that feels more like clay than plaster no fine grit at all /seems like st gobain got us all f*kd
We've been using Board Finish for a while now and it does seem better than the Multi we were using previously, but even with this I've had to change my trowelling style. Having to use much more edge now. Keeping the trowel flatter to the wall it just seems to go streaky, not all the time, just randomly. Different bags from the same pallet appear to work differently on the same (new board) background.
The Hobo
I get that with multi bags off same pallet react differently may I don't have enough experience yet
John j
Mono Don
Think this is what we used last week . Then comes through skim . Dog shite.
Just been picked 9 bags of multi gold up for next week
mark hoare
all self adhesive tape is crap,only developed for house bashing. if you want a quality job use hessian like in the 80s bit more time but no cracks. i remember going in on a saturday just to tape up the house with cloth for a monday start and it's nice to see those same houses over 30 years later when i go back to skim the artex ceilings have not got a crack in them, not like the couple of year old new builds.
Nicm
We only used the hessian scrim around the ceiling edges years ago and paper tape on the rest of the ceiling joints.You hardly use the hessian on them do you?.
mark hoare
Never paper , you might of used bandage scrim instead of hessian as it is a bit more easier to put on,what would you use scrim tape or traditional,we are talking north of £5sqm on my jobs, not your house bashing s**it.
Nicm
f**k back to whatever planet your from,you’re a pure clown.
Nicm
What the f**k is bandage scrim?,and I don’t do house bashing.Get off them drugs whatever they are andfuck off somewhere,anywhere really.
jamesthefirst
Seen paper joints fail loads of times bubbles off
On artex they used a thinner paper tape sometimes brown, this needed to be soaked in water first and often wasn’t applied properly. Paper tape I use is thicker with perforations and no need to soak unless you use skim to bed it with then I soak in water.
essexandy
The Lake Governor
The brown tape pretty much died out because of the need to soak it when Artex brought out a white tape that could be applied dry.
The perforated tape is drywall tape and can be applied dry even with finish plaster. We use a banjo for speed.
Havagojo
Not always practical but prefer to lay scrim on top of first coat and flatten in , think it has a stronger bond ( not 40 m ceilings lol)
megamix
I remember using the paper tape that you dip in water and stick on . Can you still get it ?!
