tex it all said:drapery pattern ie..artex is done like this get one 9 inch artex comb ..one artex rose comb..one 3 inch witcherdy grub . hold 9 inch comb in left hand ..rose comb in right hand ..and then insert grub into arse..then just go for it i get perfect results every time![]()
spunky said:were the kids in america whooao
if you know this information why dont the person that told you this tell you how to do itjames said:drapery texture is a sand and cement finish done with a stiff broom (25-50mm thick and 150-200mm long)
but i dont know how its done.
spunky said:has anyone done the finish where you have to whip it with willow branches ;D
spunky said:missus is plying on the wii dance game![]()
Render Systems said:i will tell you... for internal work you put the finish on thick then roller with a smooth roller to bring it up like a bark finish... then when its setting you flatten the texture in gently to achieve the pattern
