Yes mate it's happened to me and I've had the screw on caps split as well,Anyone else had this? Not sure how it’s happened. Setting up this morning it pissing out. Is it a hard job to replace?
Cheers
80 odd complete rip-off, and you can't buy the caps separate so if a cap splits you've got a buy the hole thing 80 quid for a bottle capThink they're about £70 though
Could have got you out of s***Anyone else had this? Not sure how it’s happened. Setting up this morning it pissing out. Is it a hard job to replace?
Cheers
You've got a loosen that 30 ml brass nut off the bottomTook it off and it’s just the screw piece at the bottom. Can’t get northern to answer though![]()
That’s bloody good of you Tom but I’ve done a good chunk by hand now. I’ll order tomorrow and should get it Wednesday.How desperate are you mate do you need to get spraying,
I'm with Less tomorrow and passing Stoke-on-Trent on the way back if that's any help to you
Ooof! Don’t know how mine cracked, one minute fine, next broke. Maybe been a bit rough with it getting out of the lock up and the vibration cracked it.Yep it was £80 ish as said for a bit of plastic, ours froze up and cracked.
Agree mate. Damned decent to offer.Quality
That’s interesting John. When I took the piece off at the bottom it looks weird like the plastic has broken down almost like it’s been really hot. It’s all discoloured and full of hairline cracks.Rossi46, I know the history or your machine and it went through a few tubes for some unknown reason, even Les couldn’t find the answer. Its cursed!
I suggest you get two, always have a back up.
Why would a new machine go through flow tubes. Bizarre. His lads must have really f**k*d about.Rossi46, I know the history or your machine and it went through a few tubes for some unknown reason, even Les couldn’t find the answer. Its cursed!
Its Paul Mann’s old machine, always breaking down, even for me on the one day I gave him a hand. It was a blown fuse that day. He went back to hand applicatio, it did his nut in. Worked with my old Ritmo this week, lad got it primed and as soon as I went to turn it on that broke down as well. First time in 18 months of him owning it, it sees me and throws another tantrum.
It was that Ritmo what put me on Setraline, sold it and off the medication.
So You wouldn't part with your vibrator then?Never! I couldn’t be bothered whacking the sides so the materials goes down on that old fashioned one.
Sweet mate@Rossi46 pft Scotland have recently set up a new website loads in stock and cheaper than others, just had a large order I think it's John's Mrs very helpful View attachment 52141
Yes mate it's all I do and it's 100% worth it,@Tom81 can you give me any tips on spraying poly modded base coats? Been too scared to spray them before but got a nice timber frame new build I can’t be arsed handballing.
Always wondered if it was worth it with it going on so thin.
Cool. Then that’s what I’ll doYes mate it's all I do and it's 100% worth it,
Just write a 6 mil ewi job 10 mil cap piss wet just under 300 water setting test into a bucket with the air nozzle slackened off push it forwards as you're spraying till you get a wide fan obviously got a move a bit quicker as it's only 6 ml your talking 100m by lunchtime
Ours was playing up recently, if there was room in the skip that day, it would have gone in.Its Paul Mann’s old machine, always breaking down, even for me on the one day I gave him a hand. It was a blown fuse that day. He went back to hand applicatio, it did his nut in. Worked with my old Ritmo this week, lad got it primed and as soon as I went to turn it on that broke down as well. First time in 18 months of him owning it, it sees me and throws another tantrum.
