Hi all
I did a 5 day course and no one mentioned corner bead we used a corner trowel to square the edges.
Do any of you guys use metal or plastic beads.
I was looking at the mesh render beads.
Am only asking as I'm not happy with the edges not looking sharp.
Hi all
You should be able to make the externals sharp with an external corner trowel. If you was to find a bead to venetian up to then you will still see the bead just like after plastering. Venetian is the decoration like paint and should cover the bead. I would practise more with your external edges until you get them bang on
