why not you ******* lesbo?Don't one coat !!
Go stick you're head in an oven you old ****dont sponge do it properly.........................
was going to suggest what you are already doing,,, cant help you im afraid spunky, never heard of this happening before when joints have been filled the previous set,, i wonder if filling them with bonding would stop itTapered edge boards scrim is from Travis, I've filled out joints on the previous set so there gone off etc but it still seems to happen ?
Doubt it mate
gdplastering can you explain why plaster bubbles, if not would you kindly **** off![]()
He only does love and kisses on Monday , not to sure what year :RpS_confused::RpS_wink:Harsh!!
Doubt it mate
Blah blah blah you don't know why plaster bubbles then knob jockey? If I 2 coat bonding it bubbles........ Not exactly problem free is it
It gives me a warm feeling inside Andy ,seeing "you **** and ******* and kindly **** off ,he is back :RpS_wub:I've been getting worried about you for a while Dave now I know you're back to normal it's a real relief.
I'd say fill out the tapered edges at the start of the set or even just a few joints ahead of yourself. That's what I do and although I'm two coating I can't see why it'd be any different for you one coating.
If i remember correctly you get bubbling on the finish if your backing has set but, is still too wet so could leaving filling your joints near the end of your first set help ? or is it happening on your first set as well in which case fook knows.
Don't do that, just coat it as you go, i've tried your way and essexandy's way i found they either bubbled or showed through once set, not filling before hand works fine for me, but then i do speedskim it too & can get a 4 to 5 bag hit on in under 3 hoursTapered edge boards scrim is from Travis, I've filled out joints on the previous set so there gone off etc but it still seems to happen ?
