As above..I've used plenty of limelight which I hate,I've been told this is better gear.
Ye it says that on back do not use multi finish..I've used that high impact b4 it's expensive,guy has bought a load of multi.hustled me into doing the c**t.2 of walls are old Yorkshire stone aswell deep as.told him its guna take 2-3 coats,I've done same job b4 with limelight and was a t**t very time consumingBang same as limelite. They used to say could use multi on top but have since changed there spec and need there finish on top to prevent issues.
Originally he said its soverign which I havnt used,I said to him on phone if it's like limelight I dont want the job,his words were oh it's nice to use,spreads like hardball so I've agreed job..just guna skim all ceilings and studs and dotting upstairs and if he dsnt pay what I want for doing the backing coat I ain't doing itbetter gear in what way?
it's cement based just like Limelite and dri-coat can't imagine it being any different to be honestOriginally he said its soverign which I havnt used,I said to him on phone if it's like limelight I dont want the job,his words were oh it's nice to use,spreads like hardball so I've agreed job..just guna skim all ceilings and studs and dotting upstairs and if he dsnt pay what I want for doing the backing coat I ain't doing it
That was what I said to the c**t,hes like no it spreads nice and miles better than limelite..not doing until nxt tuesit's cement based just like Limelite and dri-coat can't imagine it being any different to be honest
Dri coat is miles better to use than limelightit's cement based just like Limelite and dri-coat can't imagine it being any different to be honest
The sovereign gear is ok aswell used loads of it in the pastOriginally he said its soverign which I havnt used,I said to him on phone if it's like limelight I dont want the job,his words were oh it's nice to use,spreads like hardball so I've agreed job..just guna skim all ceilings and studs and dotting upstairs and if he dsnt pay what I want for doing the backing coat I ain't doing it
Just skim it with board finish it will be fine, i key up next day when gone off or same day if ive got to leave for a week.
2 inches in places..done it b4,built up and built up etc with limelite..aslong as it rules better..you skimmed it with multi zombie back in the day? Got 26 multi and 10 more coming tuesday..It is better gear to spread and rule than limelite...though like all those products hard work and slump if trying to build up to much depth
Why zombie have you skimmed with multi on it?Your massively wrong there pal
Does it hang like when you skim limelite?Just skim it with board finish it will be fine, i key up next day when gone off or same day if ive got to leave for a week.
This is what I agreed to use but apparantly none in stock..didnt even tell me until I opened my present today when it got droppedThe sovereign gear is ok aswell used loads of it in the past
I've used loads of limelite,hate the stuffUsed loads limelight renovating and finish
Great stuff...
Its good gear limelite I dont mind it makes a change from dab and skim bores the pants off me that shite doesI've used loads of limelite,hate the stuff
Compared to hard wall or ocr..might be because I did 7 cottages in a row using the f**k*r..price is as tight as a nuns vagina aswell,that's probably why I'm saying I hate the f**k*rHate it compared to what?
I don't like the cost of it though
Should be fun then going over this shite with it![]()
Mate believe you me this isnt my option..I'd be battening and boarding that one...could use insulated boards. I've used alot of Permaguard renovating plaster...but can't build out quickly had to do it in several coats otherwise it slumps. I dry line everything these days if i can.
Yes and like limelite backing can burn through the skim and turn it to dust
