2 coats from 1 bucket
  • Thread starter Deleted member 29624
  • Start date
Y the fck wud u use a sponge in skimming?
Plasterers many moons ago would use a wooden float to flatten plasterer before trowelling as you would using universal one coat
It works the same with multi
I had a 10m2 ceiling to skim yesterday
Started laying at 4pm so one coat it was.got the sponge on it and was out the door by 5.30
But y cant u do one coat with a trowel only? If I did a 10m2 ceiling 1 coat at 4 id be out the door by 5.30..same time bobby
Probably can fat sack
The sponge openings it up bringing grit to the surface
Helps it pull in
Helps it pull in
I always do one coat for the ceiling and always turns better than the walls . No sponge. Try next time, you will be surprised.
If I get a lumpy bumpy wall or ceiling I still use the 'trowel float trowel' method...OMG, I'm out of touch
You have a very strange mind , think we all know that it's you that's doing these things , enjoy .night night cock breath
While we're talking about beastiality...
  • 2 coats from 1 bucket
I would never 1 cost a ceiling personally, I also don't like sponging multi unless I'm outing on like a 5-6 bag hit which is rare these days ! I've Seen others do so with good results though, down to preference.
I give it one thick coat laid on flat, then another thinner coat straight over the top no flattening, take your trowel both ways and flatten it in as you go. 3 trowels and she's good to go.
