1 coat skimming with supaflex
algeeman
It’s A Boy
Can anyone 1 coat with refina supaflex ??
Easy with mt.
Had a new supaflex for 2 days.
Got the hang of it...(finish set later instead of earlier).
Any problems with joints when painted ??
I cant skim reveals with it !!
Thanks for replies.
You wont be thanking for the replies when you've heard them.
if someone's paying you to do a job and you've agreed to do it for the price, then do it properly one coat on board is abhorrent unless its been sprayed it always looks dogshite.
Learned to 1 coat bg after using mp for 3 years (non spraying).
plenty of firms only order mats too 1 coat.
2 coating is easier .....1 coating is earlier !!
I take it I cant 1 coat with supaflex ??
Tried a big hit today all seemed well just a bit paranoid about the joints.
If you can already use a mt and it's easy what the fu........... He...... Are yo.........goin.......on .......abou..........
another plasterer on our site said where he lives he does a p****e one coat:RpS_scared:
I did this with one coat with the s*p*r*lex.
  • 1 coat skimming with supaflex
Plenty of firms only order enough mats for 1 coat??!!
Dropped back 2 coating today with sflex.
Christ there is no effort at all in skimming now.
Them germans dont fuuck about !!!!!!!!
Iv been plastering long time 2 coat only until some one showed me something YES 1 coat joints first then a nice coat all over and then sponge it give a min then trowel I use a NELA 18" IT SO EASY I no a lot of you might frown upon this but if it came out **** I wouldn't use this method one thing make sure u go round all the beads twice and revels
I await your responce
Cassie Listen I hear you , but I done this for a year now and ot been pulled up once , each to their own but it takes a good hour of a hit I was always 2 coat but times move on
I worked on some right sod"s of sites where finishing foreman have been BAR----TS YOU NO HOLDING A LIGHT UP TO A WALL FROM 3" im not making it up
done this for a year... did it on my house.... found out why its a no go.
makes the surface skim brittle and weak almost dusty, once painted even when primed the paint bond is poor and can damage easy and pull away . After finding this to be true i went back to doing 2 coats with no issue.
iv heard this but been back on sites for 2nd phase of work and never had any issues I think its all about the coat u put on
you crack on mate I c u got the im the best plasterer in the world disease if I hadn't seen it for my self I wouldn't of tried it
Tried the odd time with a sponge and finish with a plazzy.. Problem is it is inconsistent .. Some times it looks great other times no so.. Only use it as a last resort
Hahah so saying one coating is shite implies im the best plasterer in the world .... your the one that can crack on m8 knocking out shite work....
The fact is it says 2 COATS on BG bags .... until it says 1 coat on them you can shove your argument up your arse ...
