Which plaster should be used on these blocks
But I would push for d+d because clinker blocks are s**t and normally have a lot of dry joints
The original spec was a German one coat plaster so I've gone with Universal OneCoat plaster from BG, the block work is horrendous in one run of 5m in one panel was 25mm out! Blocks a bit dry but with a bit of water I was away with it, couldn't belive what a good finish you could get with onecoat
Lol may need more than onecoat
battling with the courier company at the moment the c**ts
My stuff arrived safely thanks danny :)
The Mrs got all excited reading the sachet:chica: until she got to the second line :endesacuerdo:then agreed I was r******d.
Parcel arrived in glasgie just after I left :sorprendido3: so pick it up next time .(y)
