where to buy k rend
where you based ,normal rule of thumb is a bag per m2 ,but you will look a **** if you don,t have enough :RpS_crying: ,not sure if your in feet or m2:RpS_confused:
Anklets I'm near cheshire mate an use buildbase in traff park they have **** loads in mate I would get 28 bags to be on safe side depending on background are you using a base coat?if so will need less krend ft
30 bags if your going on 15mm beads will cover 25 metres just.
Dreadful coverage rate.
We just had 28 bags to do a 23m job in WP and we run out of stuff. Cost me another visit to go back just to do a column and a reveal.
Thanks mate. Wasnt going to use base coat as its straight on block work just going to mesh stress areas. How much a bag is it?
I go on 1m2 per 25kg bag at 10mm. Kilsaran recently gave me 1.2m2 per bag at 10mm. Nice stuff and also based at Trafford Park.
Think Nantwich is the closest to me. So I need 30 bags? Its going to cost about £300 its only one wall
I use lay on 17/ 18mm and scrape back to 15 every time.
My jobs can't lie on the coverage.
Many on here will tell you tho they get more than a metre a bag out of krend.
None would invite me down to see how it's done tho
Do you have to mix k rend with a paddle mixer then leave it 5 and mix again? Do you have to pva block work?
Yeah you need to.... say you go with a 6 bag mix. It will prob take 10 mins to get it mixed. Then leave for 5 then mix again for 5. Its better to use this way but still anti productive process all the same pffff
Cheers mate. Can I just mix in a gorilla bucket? Do I need to pva?
