One Coat Render (ocr) is just the same as all the other bagged more or less a polymer moddded s&C replacement grades 1 2or3 is just the strength or polymer content you can do either float up or bar/cut so if u used to cutting the likes of parmurex/cpi/uf-base then just stick to what you know cutting or floating
IMO ocr goes off quicker sometimes so plan to render in mornin and cut in afternoon... nice
yes ste and p;asterstifes right can be done same day it was cold december day that day and wasnt worried about leaving over night to be fair if you are gonna scrape it its best left till as late as poss ie harder than what you would through color to achieve the tight finish
